Thinking of selling my Savage 25
the tubing that runs down in the tank needs to be 2 3/4" inches. mine is about an 1/8" on an inch off the bottom floor of the tank.
The reason why I start with a little bit longer length of fuel tubing is because depending on which baffle you route it through, it can be too long or too short.
One more thing I forgot to mention is after you run and if you have any fuel left in your tank, make sure you diconnect all lines from the tank or else fuel will creep up eventually (even thru the one way valve) and reach the exhaust. I usually empty my tank when I'm done running.
