PaulC
RCTalk Champion
Was running the buggy again today and again it started to idle very high.
Just after I refueled it, it lost power and then cut out. Plug blown.
We quit for the day, but when I was putting ARO in it I can't turn it fully over by hand with no plug in.
The piston isn't siezed, but it hits something solid going either way round, piston in different places depending on which way you go. One way it's just at TBC the other way it's just after BDC.
Something come off on the crank shaft like a conrod pin or is the engine likely a write off?
Wish I could get it to run right again. I can't set the idle lower or it won't run, can't set it richer or it stalls out on throttle. It's just that after it's been running a while the idle jumps very high to the point it will roll on it's own and not too much smoke either
Unless I retune it once it starts doing that.
Maybe I should get a Pico .21 instead. Now I have a good buggy I could also dump the ansmann engine.
On that point, I think the .28 is too big for the Losi, it's way overpowered even at 75% throttle. I'm looking at .21's Pico or Navirossi the later more expensive. Does anyone know if any of the .21 pull start engines will fit in the Losi? I know I had to remove my pull strt to get the .28 in.
Any recommendations?
Paul
Paul
