Tekin Fx-R Running Hot
HPI-Killer
Axial Axle Twisting Guru
Northern Utah
I may answer my own question but..... I'm not sure if escs run hot but a wire removed because of a cc bec instructions has been plugged back into the plug on my rx, do they run hot or do I need to unplug that wire again? If so can I cut it off all together?
Thanks
Your esc nor bec should get very warm. You have to unhook that wire on the esc when running a bec, that disables the esc's stock bec.
