t maxx problems
351gt-40
today i finished breaking in my t maxx 3.3 when i got finished with the 5th tank i took off the factory exhaust pipe and replaced it with a outlaw race pipe,the problem now is it is hard to start and when it does start it trys to quit when you give it throttle, i adjusted the hsn which is was what recommended but it did not help, when you do get it to go it does not have any power at all it wouldnt even pull up a small hill. any help what be appreciated
Need more info... Does it blow a lot of smoke, or none at all... What are the temps?
I'm with Olds, the outlaw pipe is junk, the stock pipe is a lot better!
tmaxx problems
Is there a good aftermarket exhaust system for this truck other than the duel exhaust I've seen? i want to keep it a single exhaust but with more power? thanks
When my t-maxx was stock (wow, that was a long time ago...) I used the THS Racing pipe for a little bit with the 2.5, and it was awesome. Since the 3.3 uses the same exhaust, I'm pretty sure it will work.
I have found two different exhaust for the tmaxx 3.3, the ths exhaust and the dynamite hard annodized one, which one would be best, i want something louder than stock with more power.
