the build looks really good, really want to see more. only problem i can see being single shocked is the weight of the truck. being all alu. like that. it may be me over thinking it though tbh. will have to say the only thing i don't particularly like on the T-Maxx trucks is the engine running parallel with the truck, so much length between engine and transmission mounts. easy to strip spurs during flexing. though yours being solid aluminum that shouldn't be an issue.
I ran a 4 shock setup on my big block converted maxx back in the day. I used Unlimited Engineering Supermaxx shocks, which were modified OFNA 9.5 buggy shocks that were shorter than rear buggy and longer than front.
As for flex, that section of the chassis doesn't really flex if you have alloy chassis rails underneath. Well, my BB maxx had an alloy transmission, alloy chassis rails, RC Solutions spring steel skids, alloy bulks. So the entire core of the truck was like a brick. I ran RPM arms, carriers and towers.
The main issue back then was the cvd's didn't hold up (I had XTM conversion) and the diffs didn't hold up. Even with a mild big block, the diffs would grenade after a few bash sessions.
These were 2 of mine and my buddies:
His was the blue flames body. Had the dynamite BB conversion and a Powerhouse .26 big block. He had traxxas big bores. The GTR's didn't exist yet. He may have had Integy MSR's on it at the time of that photo, he busted almost all 8 of them on the first or second bash then went with the big bores.
The middle half bodied one was mine with the supermaxx shocks with the XTM BB conversion and an Omega Picco 21 big block.
The other on the end was just my other t-maxx with an OS15CV-R(X) in it.
Even with the BB conversion, there was barely enough room for the shock behind the header:
Here's a photo of one I found on the internet a year or so ago that shows a pretty much stock maxx with the xtm conversion on it:
