My dad just did this 2 days ago as I watched, it's not bad at all plus you can easily find an "exploded view" of the tranny online to see how it goes together. Inside are several gears stacked on each other, 2 sets. The smaller set has one gear thats quite thick and in that is your 2 speed spool. This has a spring and small metal rod in it which will spread out at a high RPM, you will see it. This is what control the shifting and also holds the set screw you turn when adjusting it. These do wear out as his did awhile back and needed replaced. Check that and of course all the teeth on all the gears, if you find no damage visually I would say replace that shifter piece, it's fairly cheap too.
