i think i have found my issue. again, being new to this, i didnt know the truck took 4 batteries. when i took everything apart, i just saw the two. the battery holder thing was jammed in the box. two of the batteries expired in 2011. i just put four new batteries in and the servo works so much better now! however my steering servo isnt working right. it turns the direction i turn, but the wheels are to one side and the farthest they will turn is back straight. i just turned it on again and now it wont even move. i tried adjusting the steering trim on the transmitter but it didnt do anything
---------- Post added at 5:06 PM ---------- Previous post was at 4:59 PM ----------
so as of now, everything is in proper working order EXCEPT the steering. I'm gonna go try and crank it up though
---------- Post added at 5:19 PM ---------- Previous post was at 5:06 PM ----------
alright so i started it and the first time, i primed it and it stayed running. WITHOUT the high rpm. it sat there at an idle like it should. pulled the trigger and it went. pushed the trigger and it stopped. then it did the high rpm thing. that couldnt have been the pin because i had it to where it would fully close on its own so that should have been mostly closed but then i even did the brakes so i know it had to have been closed.. every time after that one, it just goes high rpm before i even touch the transmitter
