motor works fine. its NOT flooded. owb is lubed and right direction. ez start DOES roll the engine, just wont start.
only other thing i know to do is take it to the local shop and let them check it out..?
DON'T take it to the shop.
I just checked this thread, and you've been everywhere except in the right place.
The engine spins and sputters. No reason to bang on the starter motor since it's working.
The engine spins and sputters. No reason to be worried about after run oil.
No reason to be worried about hydro lock if you didn't need the ARO to begin with. ARO is for storing, not starting.
Where the transmission is just doesn't matter with starting. The only thing that matters with the servos is if they are working correctly and in the right plug of the rx.
I don't know if you've primed the engine by putting your finger over the exhaust while spinning the starter, but that might be your issue.
Before starting ANY nitro vehicle make sure your throttle servo opens and closes EXACTLY as it should. Starting with it half open can result in a runaway or tire burns on your arm.
To eliminate ALL your problems, take off the air cleaner and put a little fuel directly into the carb and start the engine. If it starts, runs a few seconds and then stalls, you've got a clogged needle valve or just old, bad fuel.
