Nothing special.
I came across this while looking for sway bars for my savage XL.
http://www.rcbasher.com/savsway.html
I picked up a few items at my LHS.
I used aluminum Itengy Revo ball ends and traxxas plastic ball ends for the rest. The Integy ball ends come threaded with 4M thread, the traxxas ones will accept either 8-32 thread or 4m thread, what ever you have access to. I used 8-32 threaded rod and cut them to length.
You have to pull off the diff case, instructions to do that are in your manual. Once you have the diff. case off you have to drill out the two unused holes at opposite ends of the case. I used a 5/32" bit to make the holes big enough to get the 4M screws through.
Once you've drilled the holes and bent your 1/8" piano wire, you can assemble the whole thing. I missed most of the assembly pics, but the link I provided should fill in the rest.
seems to work good so far.
