ch3no2junkie
While running in a drag race this weekend in a parking lot, I noticed the camber on my right front wheel going all over the place. Nothing was visibly broken or damaged, so I disassembled the front end for inspection. I found the problem to be the pin that holds the control arm in the bulkhead no where near long enough. Over time and several collisions, the pin had worked it self back into the bulkhead and theres was nothing to locate the control arm.
My parts breakdown calls for this to be part #5321 and to be (4) 3x20mm and (2) 3X20 pins. As you can see by the pics, the 4 short pins are not the same lenght. The LHS didn't have part #5321, so I don't know if they actually are the correct pins for it or exactly what the deal is with my truck. I ended up taking part #2639 and cutting one of them in half. It ends up being the perfect length for the front end. Just thought I would what I found, hope it helps someone else.
