Stop savage wheelies
bplakers
Gone - bye bye.
What's the best way to keep a savage 25 with k4.6 front wheels on the ground? Everytime I punch it full throttle will pull them off the ground. Just about any type of acceleration will pull them off the ground.
There is only a few things you can do....first is go easier on the throttle. It is a variable system you don't have to go full bore on take off. Second you can gear up slightly to increase you top end and reduce you low end torque. You can also get heavier tires. That will healp keep them down. Bead locks and Mobabs are wheelie killers.
Yeah I've thought about adding the weight to the front lol...just takes off even with slow acceleration once you go to full front tires are coming off the ground. Have a wheelie bar on it you can ride them out but have te let off the throttle. The diffs are working now not making much noise since I cleaned them.
No center diff must suck :p I personally like pulling wheelies all the time. But at least revos have the option of a center diff :) have you tried adjusting the suspension? And adding weight would suck when braking and overall handling
---------- Post added at 4:29 PM ---------- Previous post was at 4:28 PM ----------
Also u could just adjust your throttle linkage so it doesn't open up to full if you don't know how to keep it down. :p
