Steering servo horns?
charliejp
Edmond, OK
I need some steering servo horns for my Savage X. I did'nt want to buy the tree for 2 horns so I was hoping to get a couple of suggestions. It's for a Hitec servo. Thanks.:\
The arms that come with the servo will work. Just use small washers to align it and a bolt with a locknut on it. I prefer to do it that way. The longer arms will give you quicker steering response with less servo travel.
You should have said something sooner. I have tons of those arms I don't use.
I'll mail you one if you want, tell me the spline count if you need it.
Thanks for the info. I've got a box with all the hitec arms so I should be good for awhile. I was just wondering if there is anything better. I've stripped 2 allready. The 1st 1 was due to EPAs not being quite right and the second, well probably the way I drive it.
Check that your servo saver nut is no tighter than 4-5mm gap from the bottom of the nut to the purple diff mount plate. The manual shows this. If it is set any tighter, it will continue to break stuff.
thatcraig
11
Tunedfrog
Tunedfrog
Pablo1980
Pablo1980
Pablo1980
rceverywhere
rceverywhere
rceverywhere
