Hi guys, I have a Kyosho V - ONE - S, and was wondering if anyone could be of any assistance with my slight steering problem.
When i turn the txer and rxer on steering is perfect with trim at neutral. After a little bit of a run the steering goes to poop, like in order to steer at all i need to change the trim all the was to the left or right. once i have done that it goes straight fora while then it stuffs up again and i have to move the trim again.
I am using hitec txer , rxer and servos
i have a hitec 503 servo i beleive for the steering not sure if it is 503, but it is 50 something. This servo i have already upgraded from a 30 someting. I also had to upgrade the throttle servo as well.
any help would be appreciated.
Also this steering problem caused a slight incident some might find funny.
The beast had a fuel leak, and i was trying to fix, when i thought that i had fixed it i took her for a run. There were no apparent fuel leaks. Was giving her a bit of a bash and came through a really fast chicane section in the road at WOT. All the sudden i lost steering (could only go straight or right) at nearly WOT she mounted the curb sending sparks. Now i bet you can guess what happened when the sparks met with all that nitro.
:flamer:
:redbuggy:
:flamer:
:redbuggy:
