if u change the screw where the servo pivots u can increase the swing. if u can't steer enough then i dont know what the go is... u must be trying to turn around in a shopping trolly...
LOL!
Are you aiming to decrease the turning circle, of increase steering speed?
By moving the steering linkages to the outer point of the servo horn (as revo5309 mentioned), it will make the steering turn in more, but it will slow it down just a smidge. You will find you will need to take a bit off the bracket as mentioned before. You wont be able to go much more than this, as you are limited by the tie-rods.
If want it to turn quicker, your only option is to upgrade the steering servos. If its taking unusually long to turn, disconnect the linkages off the servos and move the wheels by hand. If it moves free, Id suggest a dying servo. Connect one of the linkages back up, and give the controls a flick from side to side. Then disconnect it again, and try the other side. The side that moves slower is the dying one.
You mentioned in another post that a control arm was destroyed. This might relate to that. If the steering is heavy when you try and move it manually, check the servo-saver isn't binding up. Disconnect all the servo linkages and tie rods, so the servo-saver is free to move on its own, if it feels tight, you know where the problem is.
Also check that the ball joints on the wheel hubs aren't too tight, Disconnect the tie-rods, and see if the wheels steer freely. If one of them binds up, adjust the ball joints out a bit and see what happens.
