Borjawil
Just getting back into RC after a hiatus when Lipos started coming out.
Picked up a 2wd pede with the xl5 titan 12t setup. Have a brushless system and what not on the way. So I want to lengthen and widen the stance, along with ball bearings for the wheels and whatever else might be recommended.
Searching through various posts I have a few different options as far as longer arms go. FLM offers longer arms but also offers to the 1/8 scale arms. I'd like to to with the 1/8 arms but it doesn't specify if they are front or rear or both. Any one know?
Also wondering what the jato arm swap length is at? I've read the jato arms don't require longer drive shafts, if anyone can confirm that'd be great. Also if the 1/8 arms require different drive shafts and if so what works.
I understand the turnbuckles will likely need to be changed. What should I look for to work with the jato arms and the 1/8 arms?
Anything else I'm missing? I plan on upgrading the shocks towers, bulk head, and shock caps, to aluminum. Shock upgrade and other component suggestions, if needed, are welcome as well.
Thanks!
Thanks!
