big jilm
ok guys, I live in ga. It was 100 freak'n degrees outside yesterday and It was the first time I had a chance to run the revo since I fixed the carb..
It started stroung and I ran for 3-4 minutes at pretty much wot then checked the temp.. 304% !!! so I shut it down , let it cool, then richened a little over 1/4 turn on hsn. Repeated at wot 3-4 minutes and check. this time I'm at 302%.
Its running pretty rich (hsn out almost 5 turns and lsn flush) but I'm still hitting 300%..
Question is would this be normal on a 100% day in tha blazing sun wot for 3-4 minutes.... I also had the top off..
I have replaced fuel lines, tested the tank, and checked the mill for leaks and its sealed up tight.. I just can't get tha temp. down to where I need to be..
On a side not- I'm ripping wheelies and hawling a**...
