I have an older version HPI rush with the .15 FE engine. When I hit the throttle, it either does not move or it moves really slow. I keep thinking is is slipping between the spur gear and the metal that it goes up against. I have looked at the clutch shoes and don't really see any problem. If I leave one rear tire on the ground, I can spin the other either direction. Is that normal?? What can I do to make the spur gear not slip so much other than tighten it all the way down, which I have already done??Thanks for the help!
