Some Questions about my Jato
RusTLeRx350
PA
I've been looking around, and saw there were wing mounts for the Jato. How is this for it? Do I lose any top end speed? I mainly want this to be my "Street" car. Also, what tires would you recommend? I like the Anacondas, but they turned to slicks awfully fast. And my third question is: Is there anyway I can lower it? I want it to be a bit more aerodynamic, and it looks real cool. :D Haha
the wing will not slow you down, not sure how it mounts but it would look prety sweet. to lower it just add equal lengths of fuel tubing on the "inside" of the shock body AROUND the shock shaft. it simply limits the up travel. run a heaver weight oil. the anacanda's are pretty good for traction. not sure about anything else, but to help out at high speeds you can tape the inside so they dont balloon out. that will also help with wear, but not much
I don't know if a wing is going to help you with the jato. It may help protect the engine, but I have a feeling it will make your front more unstable than it already is.
The jato is really prone to wheelies, especially at high speeds. You may want to look into making a wing for the front as well.
