marauder
So recently I’ve gotten into solid axle monster trucks. Thought I’d share my first build. Started life as a new Max-D SMT10 from Axial racing. Still a work in progress waiting on a lot of parts orders. Feel free to ask any questions. Thanks!
Electronics:
Drivetrain:
Body:
Trying to keep as much stock and plastic as possible to keep the weight down. I really like the quality of the axial parts (excluding stock driveline). I believe the driveshafts will hold up and are a cheap weak point.
Electronics:
- Removed axial esc/motor
- Savox SA1230SG
- Mamba X esc and 1406-5700kv running on 2s lipo
Drivetrain:
- Replacing as things break which is fast
- HR trans gears
- Axial HD bevel gear set stock ratio for front and rear to be installed
- Axial cvd’s for front to be installed
- Proline Brawler wheels
- Prolibe Destroyer tires
- Axial flat 12mm hex (stock hex will not work with these wheels unless you drill the wheels or grind off the step).
Body:
- Modified new rear body mount
- Justin’s Customz wrap Hot Wheels body
