A little history leading up to my question. I bought the Stamped 4x4 bl-2s 2 or 3 months ago. First thing I did was upgrade the motor to the vxl 3s. Still ran it on 2s due to LHS hours and funds/work schedule. This is my first RC, and my LHS recommended it as a first purchase. Broke a few parts, then stripped spur gear. Went back with a steel one and put it in myself. Then stripped pinion (probably my fault, all I could get at the time was a 53t, stock was 54 and I used the spacer instead of setting mesh with paper). Got it back together and it no longer wheelie along with making a loud racket. Assumed it was the slipper so took it back apart and inspected and tightened. At this point went to 3s battery, still didn't perform well and still had the noise. Discovered the motor was trashed and replaced it. Still doesn't wheelie .slipper tightened all the way and backed off 3/4 turn. Still not getting the power to rear wheels which I'm assuming is a stripped rear differential. Front tires expand with full throttle, but rears don't. They do somewhat spin when taking off full throttle. Anyway I've ordered upgraded diffs and waiting for arrival. The truck seems like it's gonna be a beast on 3s, which brings me to my question. I don't really try to jump it. It mostly runs on rough terrain (grass in the pasture), some crushed concrete, and occasional asphalt. That being said, would I get any benefit from changing from slipper to center diff, or would it not be worth the expense? I'm completely brand new to this so all advice will be appreciated.
