- In my recliner
- Flying
Yes, but I get the impression from him that it idles normally, spins the tires when off the ground, but won't go faster than about 5 MPH when on the ground. Something is not fully engaging. If the clutch shoes were stuck, it would move out at idle, and would still accelerate, but would be difficult to stop, unless it stalled.
Note to tbsleeper.........
Can you shift it into reverse?
Just re-read your post, SkyMaxx. Interesting theory....what if the shoes are stuck in a dissengaged position? That might create his problem. I once had the tranny shifting too low, and ripping around in 2nd gear without downshifting made the clutch too hot to pull any more. I just got high engine revs and no forward movement. After cooling it down and adjusting the shift point there was no problem.
Also, tbsleeper, did you cool down the truck before trying it again?
