Having a problem with my idle'ing. Took my truck out after 7 months of sitting and started it up without checking the carb, went into full throttle. Hope the engine is ok, not started it since. I took off the air filter and noticed the idle is effed up. When brake is full on, it is as idle should be. On idle, it is out far, close to full throttle. I am only able to set the idle to change what happens when braking, I'm new to all of this so how do i make idle, idle?
