Clintd
Anybody use the Hotbodies shocks on there savage? If you do here is a little trick for you.
The problem I had was the steering linkage hitting the spring. I tried to change the link end but couldn’t find one that would thread all the way down. So I made my own.
Here is the original problem
Here is the original shock
Unassembled
So what I did was take an extra ball link and cut off a ¼ inch of the collar. Then I drilled it out to 1/8th of an inch.
Then I cut ¼ of an inch off of the bump stop.
Here is the part’s I’m left with.
Partly assembled
And fully assembled
Now it’s installed on my savage and there is no more interference with steering.
The reason for doing it this way is now the shaft still goes all the way to the end of the ball link (So there is no weak plastic link) and all the shocks still have equal travel.
Unassembled
Partly assembled
And fully assembled
