Arma
- Crawling
- Flying
I was casually driving when my lights shut off - I stopped the rig to investigate and saw a smoke and wiring on fire. You can see it was caused by a pinch point that led to a short. Axial's engineering is lame and their manufacturing is lazy - the best thing about my SCX6 was a complete disassembly and re-assembly properly and upgrading 90% of the parts after I understood its weak points.
The pinch point between rails and center mount caused an internal short / high resistance, which started a thermal runaway, cooked the insulation and started a fire.
- Never trust pre-wired lighting harnesses blindly, especially on RTRs—they’re often underbuilt and routed poorly.
- Always run a visual check under the battery tray or body mounts—pinch points are surprisingly common.
