Scx10.3 servo
thatcraig
Ky
  2. Crawling
  3. Scale Builder
I need to know where to get an original servo for my scx10.3 bronco. Any links would be appreciated.
Is that the servo that originally came in the truck?
Just curious, why do you need the original servo? RTR servos are all pretty crappy.
Because I can't get the aftermarket servo that I bought to fit my truck.
OEM servo was 15 kg..Dont get why you need stock servo makes no sense..but a better-upgraded servo make sure the sweep is the same as stock and Id go 25 kg.but you do you
do you think he knows what standard is ..it aint OIL..its a 1/10 scale servo
go to servocity look up the stock one you will see what servos can sub for that one.use the resources in your power your on the net go surfing stay away from the sharks(bad pun)
Well, he does now
I can't get the aftermarket servo to hook up to my links, so I'm thinking with stock links the stock servo should still fit an work.
The stock servo is a Spektrum right? They are 23t servos. So you would need a servo horn to connect to your aftermarket servo to use it if it has a different spline on your servo gear. All of these things can be purchased. What servo do you have? Pics of everything would help.
You likely just need a servo horn to match your servo's spline count.
Well my front end is having problems, it picks itself up and lowers when I give it gas on the ground. And the steering won't steer its only steers a little left to right. I've tried everything I can to make the servo work but everything binds up when I put the links back on the front end. The steering link won't steer my tires.
