Today I did break-in my XL, first tank static-idle and second, third tank half throttle driving around. My idle needle seems fine, the car isn't moving and wheels aren't speenning even when you lift the car, so that's fine. But, I still have the feelinf that it is till too rich because it doesn't go as fast as XLs that I've seen on you tube and for instance I wasn't able to lift front wheels at all while driving. Sometimes when I increase the throttle the car would shut down.
Should I lean out the high speed needle until I get better performance?? Should I adjust low speed needle at all? ...if both - which one is adjusted first then?
Thanx heaps
Thanx heaps
