- Thread starter
- #21
I will look into the springs but the space is pretty tight to get something in between them.HeartBreak said:I know how ya feel - I'm just havin a hard time visualizing it. The only things I can think of is the disc brake clamp-bars being too tight to the disks, or possibly the gear is too large for the case (doubt it).
Have you tried to remove the brake discs completely off the trans case and try to spin it then?
If it makes ya feel any better, my reverse module was the same way; it was locked up for some unknown reason. Turns out one of the gears was sitting tooth-top-to-tooth-top with another.
But if your trans only has the bottom shaft in it, and that's not rotating, the only thing that could be locking it up is the brake setup. Perhaps fit little springs between the brake plates, to push them apart?
I will try to take it apart and re assemble it again... Thanks HB.
