majin
My love for RC: Intact. My RC cars: Not so much
RC Showcase: 8
- kentucky
- Racing
- Crawling
- Scale Builder
need to save this so i can check it and ask questions as they arise
my son and i are HELLA excited ( me more than him tbh lol) to enter into this race series.
*The racecourse layout and event format will be discussed in the prerace driver’s meeting. Each participant is required to be present during the prerace driver’s meeting. Any questions can be addressed during this time regarding the event and scoring.
• Drop qualifying and run a random bracket or seed based on points after the first race. • Each participant will qualify their truck(s) on each lane of the racetrack. The best time will be used to seat the truck into the racing bracket. Any truck that does not receive a qualifying time will be given a DNF (Did Not Finish) and be placed into the bracket accordingly. The truck with the fastest qualifying time will get lane choice in eliminations.
• Once a racer has “staged” his/her truck at the starting line, the other racer has one minute to stage their truck.
• A five-minute grace period will be allotted only if the racer encounters a problem at the starting line. Each racer will be allowed to receive only 1, five-minute grace period per race.
• If the truck moves across the staging plane before the green light is illuminated, this will result in a false start. This is an automatic DQ, and the other racer will advance automatically to the next round
• Trucks are required to come into contact with obstacles (i.e. crush cars, jumps, or corn box) with the FRONT TWO tires of their truck. In races including corn boxes, your truck must stay in the box for three quarters of the boxes length. Track Marshaling is not allowed. If your vehicle flips over and can’t be saved by its own power your run is done.
• The truck may not hit or come into contact with any part of the timing system or its barricades during the run. If this happens, it will result in a DQ. (when in use)
• When trucks are competing and both completes an illegal run, a re-run will take place with trucks changing lanes. If only one truck makes an illegal run the opposing truck will be granted the win only by a legal pass.
• In the event that all four tires go into the opposing lane, the truck will be disqualified. If only two tires cross, and you are able to recover, you are safe. If a driver runs into the opposing lane and makes contact with or inhibits forward motion of the opposing truck in any way, it will result in a DQ.
• In the event that a racer with multiple entries in the same class should have to race themselves, each truck will run one timed lap on the track in separate lanes. The truck that records the fastest lap time will advance to the next round.
• In the event that a winning competitor cannot make it back for the FINAL round of racing, the competitor they beat will be inserted back into the bracket.
Retro Monsters
BODY Classically styled bodies only (1996 and earlier). Does not have to be replica but must be period appropriate. Allowed 1 body change per season.
CHASSIS Any chassis fitting in the spirit of the class (i.e. no tube frames) are legal. May be any material. sicNme Products, JConcepts, Sutton Motorsports and Crawford Performance Engineering all make legal Retro Clod Buster chassis’, among others. Trucks MUST meet a minimum weight of 9 lbs. to be legal (see weight requirements below for details). Season points are tallied with a given chassis. If the chassis is changed during season, points will not transfer.
SUSPENSION Suspension must be Tamiya Clod Buster-style, utilizing Clod Buster ladder bars, axle braces and anti-rotation brackets (or equivalent aftermarket of each). No 4-link setups or 4-link triangulation of any kind. Sway bars, sway brackets or sway braces (of any kind) are illegal. Any pivot-style, cantilever or similar suspension setup is illegal.
GENERAL/AXLES All vehicles must have a minimum of 2 solid axles. Shaft driven trucks will be allowed if it adheres to all other regulations. TIRES Chevron tread, fully cleated (no cut tires) Clod Buster sized or bigger. Tamiya Clod Buster, JConcepts Firestorm and Gold Year, and RC4WD Michelin MEGAXBIB are legal. Pro-Line Destroyers, Devastators and Demolishers, RC4WD Rumbles and B&H, JConcepts Renegades, Launch, Knob, JCT, Firestorm Racer & Firestorm Runner, Bajas, Losi LMT or any other “modern” style cut tires are all prohibited. Dual Tractors are legal. No shaved tires are allowed. Certain exceptions may be made in an attempt to recreate a certain vehicle of the specified era, at the discretion of a BMM admin team and must have prior authorization before an event day. Any Losi LMT short-course style wheel/tire is NOT allowed. WHEELS Most scale appearing monster truck wheels are legal as long as it does not put truck over max width. Any Losi LMT short-course style wheel/tire is NOT allowed.
WHEELBASE No limit. WIDTH 15.5″ max width on all trucks (outside of tire to outside of tire). This is half inch over stock 14.9″. MOTORS All 27T machine wound motors are legal. NO hand wound motors! One motor per axle allowed.
BATTERY Limited to one 7.6V 2S lipo with 120C advertised discharge limit. “Cycling” of batteries is prohibited! STEERING May be 2 or 4WS (or more than that if 6×6 or above).
SHOCKS No maximum number or length. May be oil filled or friction. Leaf Sprung Suspension will be allowed. GEARING Gearing is open, with the understanding that vehicles must adhere to our maximum speed as stated below. Each vehicle will be subject to a speed test at each event and will be asked to adjust settings to make that vehicle fall at or under the maximum speed allowed. Any vehicle may be subject to a random speed test. MAXIMUM SPEED Vehicle cannot exceed 10 mph (miles per hour), as tested by a BMM admin on each race day, using Bluegrass Monster Mash RC equipment. Each vehicle will be subject to a multiple-pass speed test. If a vehicle exceeds 10 mph, the driver will be required to adjust settings to bring the maximum speed of the vehicle down and then retest. Once the acceptable speed is achieved, that vehicle’s speed is not to be adjusted during the remainder of that race day. Each vehicle may be subject to random speed tests during the course of a race day. MINIMUM WEIGHT Vehicle must be weighed in competition trim with battery and meet a 9 lbs. minimum weight, using BMM approved equipment. Any vehicle may be subject to a random weight test.
Sport Modified
AXLES All vehicles must have a minimum of 2 solid axles. Motor on Axle (Clod Buster) gearboxes are legal. Shaft driven trucks are legal.
TIRES Most Clod or USA-1 sized tire is legal, and cutting is allowed. Any Losi LMT short-course style wheel/tire is NOT allowed.
WHEELS Most scale appearing Clod Buster sized monster truck wheels are legal. Any Losi LMT short-course style wheel/tire is NOT allowed.
CHASSIS Any scale appearing chassis is legal (tube or plates). Season points are tallied with a given chassis. If the chassis is changed during season, points will not transfer.
WHEELBASE No limit. The maximum allowed wheelbase is 14 inches.
WIDTH No limit. The maximum allowed width is 16.5 inches.
MOTORS 17 turn brushed motors are the maximum allowed (NO brushless and NO hand-wound motors), with a two-motor maximum.
BATTERY Limited to one 7.6V 2S lipo with 120C advertised discharge limit. “Cycling” of batteries is prohibited! STEERING May be 2 or 4WS.
SHOCKS No maximum number or length. May be oil filled.
SUSPENSION 4 link allowed with any type of configuration. Any suspension setup is allowed.
BODY Any scale body is legal.
Pro Modified
Motor on Axle (MOA/Clod Buster) gearboxes are legal. Shaft driven trucks are legal.
TIRES Most Clod Buster/USA-1 sized tires are legal. Losi LMT or other short course style monster truck tires are legal not allowed.
WHEELS Most scale appearing Clod Buster sized monster truck wheels are legal. Losi LMT or other short course style monster truck wheel is legal not allowed. CHASSIS Any scale appearing chassis is legal (tube or plates). Season points are tallied with a given chassis. If a chassis is changed during season, points will not transfer. WHEELBASE No limit. The maximum allowed wheelbase is 14 inches.
WIDTH No limit. The maximum allowed is 16.5 inches.
MOTORS Two motor (brushed or brushless) maximum. no limit.
BATTERY Single 2S or 3S lipo or 7 cell NIMH are all legal. “Cycling” of batteries is prohibited!
SHOCKS Any allowed.
SUSPENSION Any allowed.
LMT SPEC
Axles All vehicles must retain stock plastic axles or plastic equivalent. Tires Stock (3.6”Inner Diameter x 2.6”Outer Diameter) LMT Monster truck tires only!
Wheels Stock LMT short course style wheel only! (i.e 3.6” inside diameter and 2.6” outer diameter wheels)
Chassis All vehicles must retain stock metal chassis plates. Front and rear chassis can be trimmed for body fitment only. Roll cage can be removed. NO LCG parts are allowed. Stock esc and battery tray must remain in vehicle and in their respective stock location.
Wheelbase Wheelbase has a maximum of 15” to include the stock lmt bog hog and king sling trucks. Stock maximum of 13.5 inches.
Width Stock Width as it came out of the box must be retained.
Motors Stock 3150kv Spektrum or stock Spektrum 2800kv motors are the only allowed motors. The pinion gear may be changed.
Battery Single 2S or 3S lipo Steering Must remain stock. No rear steer allowed. Servo changes are allowed. Suspension Stock shocks and sway bars must be used, remaining in the stock location. No link mounted suspensions allowed. Stock 4 Link bars must be used, no treal or aftermarket aluminum link bars allowed. No aftermarket sway bars are allowed. Rear springs must be Losi “blue” and Front springs must be Losi “yellow” as it came from factory. Shock oils and spirngs may be changed. Body Any scale body legal.
BOX STOCK MINI LMT SPEC
Axles All vehicles must retain stock plastic axles or plastic equivalent. Diff oils may be changed in all 3 differentials. Tires Stock mini LMT tires only. Wheels Stock mini LMT short course style wheel only. Chassis Stock only no aftermarket parts can be used. Wheelbase Wheelbase must remain stock 6.8 inch. Width Stock Width 8.1 inch as it came out of the box. Motors Stock motor 380 – 25T. Stock 15T pinion ONLY Battery Stock 7.4V 810mAh 2S 50C max Electronics Receiver may be changed Steering No rear steer allowed. stock servo must be used. Suspension Stock shocks must be used. Stock springs and spring placement must remain stock. Shock oil and springs may be changed. Shocks must be mounted in the stock location. with stock shocks and springs only. Body Any scale body legal
4x4 Open Class
The only vehicles that can enter this class are vehicles that DO NOT meet the criteria of ANY other class but meet the rules listed below. Motor Maximum of 2 brushed or brushless motors Battery 1 – 2s or 3s hard case battery Chassis Any chassis is legal. Tires/Wheels 2.6 inch inner/outer diameter. LMT size wheels allowed with maximum tire height of 5.5 inch. Wheelbase Maximum of 16.5 inches. Width Maximum of 18 inches. Axles Vehicle must be 4wd and have 2 solid axles with either 2 or 4 wheel steer. Axles can be motor on axle or solid with ring and pinion. Transmission Must be a centrally located ring and pinion style transmission. (if not using clod style axles) Steering Any steering setup allowed. Shocks Any shock setup allowed. Suspension All suspension setups legal Body Any scale body legal
Retro Monsters
Sport Modified
Pro Modified
SHOCKS Any allowed.
LMT SPEC
4x4 Open Class
