rs4 + something i need=donuts and drifting
they would have to sell them seperatly cuz what happens when you buy the kit and your tires wear out
I'm running a fantom fr15 03 and i can drift most of the time. taking out the rear dogbones is a big no no with a high hp engine. the only thing that will hapen is that you will whip tehe rear around and do a doughnut. try putting heavyier out in the diffsand use some really hard tires or get some drifting tires
i forgot who makes them but they are like hard plastic with a rib on them so that when you accel it expands and slips all ove rthe place. i saw a vid at a friends house of it. looked dam fun
i found them at yokomousa.com heres a pic
about 24$ for a set of four
:idea: Here is also a tip to setup drift tires. Go to your local hardware store & buy a PVC or ABS pipe. Make sure the diameter of the pipe is close to the diameter of your wheels. Cut out a section of pipe that is the same width as your wheels.
Now simply put some CA glue on your wheels to lock them into the pipe. You might have to trim the wheels slightly to make them fit into the PVC.
That's it. You now have some drifting tires & a pipe only costs a couple of bucks and will definitely make you more than 4 sets of tires.
Later...
