RPM a arms finally to EXB and V5 arrmas
rccar4life
  2. Crawling
  3. Scale Builder
  4. Flying
  5. Boating
https://www.rpmrcproducts.com/shop/a-arms/front-a-arms/arrma-6s-front-left-arms/
RPM 6S Front A-arms fit V5 / EXB editions of the ARRMA Kraton, Notorious, Talion, Fireteam & Outcast. The design modifications we incorporated accommodate changes made by ARRMA for V5 and EXB versions of these vehicles.
Beefier: Our A-arms are significantly beefier than our original 6S version A-arms. Lower A-arm support beams are 30% thicker while upper A-arms are more than 22% thicker. The added thickness not only improves durability and strength, it also reduces flex. Less flex equates to more predictable suspension performance and handling.
Extra Suspension Options: The lower A-arm has an added shock mount hole further outboard. This additional position provides a lower profile suspension set-up. The shocks lay down a little further, dropping the ride height for a lower center of gravity. A lower center of gravity equates to higher corner speeds.
Caster Clip Elimination: As for the upper A-arm, we eliminated the caster spacers. This gave us room to widen the arm at the inner hinge pin mount. The extra width creates more of an “A” shape, stabilizing the upper A-arm. A more stable A-arm improves steering and suspension performance while adding strength and durability.
Ooooooooooooooooooo liking the red!
I'm on my 3rd front and 2nd rear arms on my kraton exb I got back in October. Only run the thing 4 or 5 times so far. Been running RPM on my 2018 outcast since I got it and only broke 1 or 2 in all that time.
Bit of a premium on that price though. Oh well, would rather replace once and move on.
View attachment 146630View attachment 146630
Just got them today
