I installed this slipper clutch and noticed the spur gear is off a bit and does not line up perfect with the pinion gear on the engine. It works fine just about 1/16 of the spur gear does not make contact with the pinion and is not wearing even with the rest of the gear.
If I was to shorten the spacer that goes between the gear and trans they supply the gear would hit the battery box.
Any one else have this problem ?
