- Thread starter
- #21
Well got the clutch spur and pinion to line up fairly well, not perfect. I tried every combination possible and just ended up flipping the gear around, had to grind the batt box a bit to get the screw heads to clear. I also machined down the end of the blue plate just a bit to make the alignment better. I also did not use the spacer that came with the kit.
