lockdo6307
So I got a Robinson metal spur gear and it comes with a Bearing rather than the slide on hex my issue is two things. One I can't get the bearing to slide over the hex on the transmission. Sorta stumped on that... I was told to sand the hex a little? Idk. Also I couldn't get any slipper pegs into the holes on the gear. Should I buy an upgraded slipper clutch or is there a special trick to getting the pegs into the gear on a medal spur gear
Sent from my myTouch_4G_Slide using Tapatalk 2
