Paintphreak
- Racing
Ok, so the story goes...
Just picked up my first nitro rc, the Revo. The truck is used and obviously an older model, but seemed to be in good overall condition. The engine has been converted to pull start and he told me he diengaged the optidrive and has the traxxas controller without the reverse switch. He also told me that doing so looses the 4wd and reverse but will still go in 2wd.
Here's the problem, i've tried to start the truck and succeeded, but the throttle sounded and acted like WOT!!?? so, i shut it down before it got out of hand or revved up too high. I tried a second time and had the same result. Since i've tried to read thru many forums and even printed off the factory manual for more info. Tried the factory reset of the carb, to go 4 turns from close on the hs needle and flush on the low speed and since hasn't fired at all. I know i flooded it, and know how to clear it, and have done so several times as well. Also checked the glow plug in the ignitor, seems to work properly, and replaced the gas tank as i was looking for leaks and couldn't get it to seal up. I'm running out of options and can't believe this simple engine is this difficult to fire! Just want to get her up and running and the only other thing i've com across is somebody mentioning using a hairdryer to heat up the block, but i do keep my truck indoors, but it is only 33 outside right now! Any help or insight would be greatly appreciated, thankx!!!:\
