Revo servos problem
Rooky
RCTalk Qualifier
Michigan
Hi people. i just put my new revo together today :D
my question is, when i give throttle, the servo turns braking direction, same for steering, when i turn left, it turns right..
there is a menue tree, but theres no monitor to display, i believe i plugged in battery correctly, other wise it wont even turn on.. any ideas?
Do you have reverse switches on your tx. That would be my first guess.
nope, and after mess around with the menue tree thing, it will not even connect anymore...... should i go to my hobby shop or is there a easy fix <,<
1st traxxas car =)
I'm sure some 1 here has the info to help you out .
What tx is it. Stock ?
Sounds like you need to revers the servos on your controller. Seriously that is the problem.
Try this out see if it helps
[ame="http://www.youtube.com/watch?v=ce6pJbJ0ftc"]Reverse Steering Servo Traxxas 2.4Ghz Radio - YouTube[/ame]
Reason for not connecting was cuz battery was dead. But still work as reversed...
---------- Post added at 1:12 PM ---------- Previous post was at 1:02 PM ----------
Wow, thanks sooo much. Worked :)
Ya, I'm not using the stock servos :)
