Revo motor pistition adjustment????
Nitratex
Ashland KY
Hey guys and gals. I just bought a revo with a big block and can't figure out how to adjust the way it lines up with the spur gear. I know the paper trick but what screws do I loosen to move the motor.
Thanks
Bill Helms.
Should be one under the motor in a forward/back direction. Unlike the mounting screws which will be up and down.
Thanks ill give it a look. Would I look under the exhaust end or the carb end of the motor.
I bought it this way I think it's a traxxas bb kit here's some pics
I had to Jerry rig the throttle bc it wasn't hooked up when I got it and didn't want to pay 50 bucks for just a few pieces but this works just fine haven't had a problem out of it yet.
This is the Allen bolt to adjust the mesh. Loosen it and pivot it up or down. Also loosen the other one one, but it doesn't move up or down...
---------- Post added at 12:51 AM ---------- Previous post was at 12:49 AM ----------
I'm assuming there is no cover on the Roto start so it can clear the a arm because Traxxas BB mount is for bump start only.
Thank you ausher and yes you are correct. I was going to switch it to a pull start bc I only have one cordless drill battery. Luckily the boat I just got came with a roto start as well and the starter solving that problem.
Thank you for the info though.
