Revo head on Rustler
JSY0829
Mount Pleasant, Michigan
Is it ok to use a Powertune Revo head on a Rustler with a TRX2.5? It can't hurt right? Also, how do you take the old head off? This is my first nitro and I'm a newbie.
TIA
If the rustler has the new 2.5 or 2.5r engine it will work as a direct replacement.
To take it off, there are 4 or 5 little hex head bolts that you can see if you look straight down from the top of the head, all the down to where the glow plug is. Just remove those and reuse them to install the new head. Do not over tighten and also do not lose the head shim that you will see when you take off the old head.
Revo is right direct replacement if its a 2.5 or 2.5r There are 5 screws that you'll have to take off to get the head off.
