joshman1204
Had my 3.3 out running today and it died at WOT and will not restart. I checked the temp on it as soon as it died and it was around 250 and still had 3/4 tank of fuel. The carb was loose in the neck so I pulled it out and check for any debris and re tightened it but it still will not start. I also pulled the tank and fuel line off and put it under water to check for leaks and had a very small leak out of the tank lid o-ring but I dont think it would be enough to keep the truck from running.
I reset all needles to factory and the truck keeps firing but will not run more than 1/2 second or so. I tried leaning the HSN and even richening the HSN from factory settings with no luck.
I dont know what would cause the truck to just instantly die at WOT it didnt bog or lose power or anything just wide open and then instantly off. I do notice now that there are some air bubbles in the fuel line that will not move no matter how much I crank the engine almost like it isnt pulling any fuel.
