- Thread starter
- #21
Lemme know how much you want, i may take it off your hands
Lol that was a Joke It's only a month old.. I'll figure this problem out..
lol. u need to take the box out. turn the input shaft. put some pressure on the output shaft and see if its working. if you can't feel the pressure on the output then its something in there. if you clutch and slipper etc are all good. then move down the line. check the drive line. take the drive shafts off and check to see if there stripped on the inside. if the center shafts are fine and then ur 4 drive shafts are also fine then you'll need to check your diffs. but i doubt they will be your problem.
instead of replacing the servo, just push that rod in so that it shifts into a gear and start the motor.
did u take the pins out of the gears or just check their there? cuz if they snap in half or 3 pieces they might still be sitting in there.
