Hi,
Was running my Revo the other day all was well.. Took it on the football oval and on the way back it came to a stop, but continued to Idle.. Pushed the accel and No forward movement.
So I was like Cool it needs the Slipper clutch screw Tightened.. Did that and nothing.
Took it home and found the slipper clutch had a half pad on it. So replaced thinking this would solve the problem.. Nope
*Pulled the Tranny apart All teeth are intact..
*Took the motor off and checked the bell Clutch pads, think thats what its called (Two pads with a spring around it) It looked ok I think.. Not sure what a bad one looks like as its my first RC..
After all this I put it back together meshed it up.. started it up and No movement.. The wheels want to move , but no :\ Even off the ground the wheels dont wanna turn and the car just Revs.. Definatly not the brakes either.
With the tranny should you be able to hold the drive shaft with a Hex key and Turn the slipper? and do the opposite -hold the slipper and turn the drive shaft?
Was thinking the Drive shaft?
If you can Help CHEERS
