Recommeded upgrades
cptvkirk
I've been seeing a lot of questions and requests for recommended upgrades and even asked for a few of my own when I got my car just a few short weeks ago. I'd like to take minute to share both my experience as a noob as well as a few, what i would call legitamate, recommended upgrades for the revo.
First, the revo, as it shows up at your door and first day out of the box is a very well planned, engineered and put together rc. It's durable, handles well for a truck, is predictable and comes with outstanding instruction and reference manuals and backed by top notch customer support. With that said there are a few things that I've learned are not what they should be..IMO
1st. Tighten everything. First time my rc was at wot was the first time i got passed by my own tire. Embarrassingly enough....3 different times. It's aluminum, give the wheel nuts a good grunt. Everything else, go over and check it all. good time to learn how the car is put together and familiarize yourself with your tools.
2nd. Clutches. Both the slipper clutch and the centrfugal clutch. Slipper clutch for some reason is looser than normal. so much so that it can toss pads. main clutch from factory is hit or miss, some work fine for a long time..some toss springs in the first few tanks. have a back up for both.
3rd, ditch AA's in rcvr box and get flat pack. This will require you pulling the power switch out turning it around so ON is actually batt connected to rcvr when switch is in that position. For some reason traxxas connects the red remote charger lead to the rcvr and lets the short black one hang then installs switch backwards to compensate rcvr box stencils. When you put in the rcvr pack simply turning switch around, connecting black to rcvr and plugging red into remote charger receptacle will fix the issue, or you can remember it's labled backwards now.
4 Temp idicator, on board or hand held, and safety cut off. Better yet is a combination of the two. Even better than that is a 2.4ghz radio that sends telemetry back to the transmitter.
5. Install a wingmount and wing...and remount old bumper to it. Trust me...you'll see.
6 The first thing to actually break on my rc was a rod end. the rebound of the suspension over time wallowed out and eventually broke my rear shock shaft end rod end connector and hollow balls.
7. Periodic inpections. gear mesh, screws, throttle and brake linkage and general condition and security checks to make sure it's all still where you started with it.
Those basic items should be more than enough to keep your rc going and ready for a fun ride at a moments notice. don't spend a lot of time and money on things you don't need.
Lastly, to quote Amoeba "read read read" there is ample information in the books to get rolling and keep it that way. It it ain't broke...then leave it be.
nice info but it doesn't really say what are the recommended upgrades.
Heh heh, well, I could have been more clear. My ONLY recommended "upgrades" are:
-Wing with mount....simply for protection
-RCVR battery pack, AA's shift and break contact
-3 shoe clutch, factory clutch for me has been fine thus far but i have a back up since 2 other revos here had their spring fail
-On board temp indicator. a new radio that sends tylemetry back to the transmitter also very nice but not so necessary.
My point with this posting is that these are the only things on a bone stock 5308 fwd only 3.3 revo that have given me issue despite absolutely beating the ever living crap out of this car on a regular basis. I based this info on the now 3 identical model revos that run where I am in Iraq. One clutch failed during break in, I tossed a slipper clutch pad shortly after break in. I landed on my head once hard enough to bend cooling head fins and shift engine in mount nearly destroying a spur gear hence the wing recommendation. Everything else on this car has been working as advertised actually exceeded my expectations. We have other cars here, some heavily modified, some not so much but all have had significant issues doing or attempting the same thing the revo does on a regular basis. E-maxx and savage...heavier and destroy a arms on impact, hubs are a common fail item as well for some individuals. The track we built is a little over the top. Not specifically for racing but more just for fun. cars take a beating. The first thing to actually break on any of the revo's was a rod end finally let go on the shaft of my rear shock. The other side is wallowed but not broke yet so i replaced them both. At pennies a piece, i ordered a few spares.
I'll edit this original post as more issues become evident but for the guys like me who don't have the largest budget available or aren't sponsored by Mom, These basic recommendations go a long way to preserving what is already a good running machine.
We also have a revo that had about 350 bucks of aftermarket stuff added to it before it even cranked the first time. It got broke in last night and will be running soon. I look forward to seeing what item is the first to fail for him.
Please don't misunderstand my point, there are a lot of cool things out there that just plain look good. I'm simply taking this from the perspective of form and function. No doubt and experienced racer has absolutely no use for this information. It is my sincerest effort to provide information for those who may only have just this one car or a tight budget to be able to sort out what may actually help them stay on the track or where ever longer from expensive mods that may or may not actually provide any increase in performance or capability.
I agree the talons aren't the best tire, mine have torn on the sidewall already but a little ca glue keeps things in tact. The ground here is rediculous hard and our "track" is like concrete under talc so the talons actually grab fairly well and don't grind off in an hour.
Hey cptvkirk I like the new jumps! Can you give me copys of the jumps I made. Id like to have them. I have my new computer comming this weekend and some new good video editing software. I would like to ad that! DRS Timmy is gonna sodder my steering servo wires again. One broke loose! Again!. Might be up for a new servo!
