I can’t seem to take out the white plastic round thing on my team associated tc3
I removed the clip but the white round part won’t come off in the manual it says to remove this part but I’m not sure if I need to brake it offThere should be a small c clip holding the piston (white plastic round thing) to the shock shaft. You'll need to remove that clip and the piston will then slide off the shaft.
I removed the clip that was holding this part but it still on therelooks to me like the shock cap is some what still there is it broken off . shock inside should be smooth .
There is a C clip holding the shock piston on. Use a small flat head screw driver to remove. It will be tricky. Or just remove the shock ball end and push the shaft threw. then you can work on it easier. You can replace C clip with a E clip laterI can’t seem to take out the white plastic round thing on my team associated tc3 View attachment 126506
You didn't even tell him HOW to remove it or even na other option to getting it off.Wow, if only someone had told him about the c clip sooner. Oh wait, someone did, and, he got them off. Did you even read the other replies?
He already had them off by the time you replied. Although I was glad to see you didn't tell him he needed more oil content to get them off, since that appears to be your go to answer.You didn't even tell him HOW to remove it or even na other option to getting it off.
