Hi all:
Back in 2018 I bought a used RC10T3 from a seller on eBay. The truck came mostly complete, needing only a body. I added the missing parts, tried it out in my neighbor's driveway, and all seemed okay. I didn't adjust a thing. Notice the Team Associated brushed motor in the photo.
Last week I replaced the ESC, receiver, and steering servo with modern units
Yesterday I decided out of the blue to run it in my backyard after I mowed. I noticed that though the steering servo was working well and had proper throw that the car had trouble turning left, and that the left rear wheel was getting power much better than the right rear wheel. I took the car to the driveway next door and did a couple of speed runs, it is really fast.
I decided to check into the drive issue after I played a bit, I'd run the car for about ten minutes. I found that no matter what I did with the nut for the slipper disc the problem persisted. I went to remove the right wheel to take the right suspension apart far enough to reach the adjuster for the ball diff but discovered that I don't own a single nut driver that will remove the wheel nut, so I ordered a nut driver. I'll try tightening the diff when the nut driver I ordered arrives on Wednesday.
In the meantime I did some looking around, I'd like to run the T3 on the indoor carpet track in Beaverton, OR so I'd like to install a gear diff. But I can't seem to find one that works. Also, in case there isn't a gear diff available and if the diff in my RC10T3 is damaged, what part of the diff is the most likely part to have been damaged and are there any parts to replace the damaged part(s) with?
I considered the re-release transmission Team Associated came out with last year, but it doesn't appear to be a direct replacement for my current transmission.
Thanks in advance to anyone who can help.
