RC is bucking
timmyoleboy69
when it is sitting on idle it is fine then i ease on the throttle it starts bucking then it kicks into gear then it is fine no problems any suggestions
Would this happen to be a TMaxx with a black transmission with reverse?
If so, the bucking is totally normal.
You can either remover reverser and install the forward only conversion, or do the no buck mod.
Or you can adjust the output gears so they engage at a lower rpms (this can cause the transmission to hang in between forward and reverse)
it is the black transmission
---------- Post added at 7:51 PM ---------- Previous post was at 7:49 PM ----------
where do i get a better transmmission
Actually thats a great transmission once you get rid of the reverse by installing the FOC (forward only conversion).
