I have an SC10 with a castle creations brushless motor that I usually run on a 2s dynamite Lipo. I was running a 14 tooth pinion and the stock 87 tooth spur gear until the spur stripped from the pinion setscrew coming loose and slipping off the motor shaft. I ordered a new 77 tooth spur gear. I went to install it but the motor cannot slide forward enough to fit the 14 tooth pinion. I have a pinion sitting around that is a 21 tooth that I can put on. I was wondering if that gearing combo of a 21 tooth pinion and a 77 tooth spur would work ok based on the electronic I have. Do you think it will make the motor too hot?
