Rub it on, let it sit, then put some 99% isopropyl alcohol in a spray bottle and hose it out or buy some electrical contact cleaner. Try not to let your electronics sit for a long time with batteries in them.
the file is 160 grit the Q tip is 600grit either will work. the Q tip is stuck on with super glue the file can be purchased on amazon its a set of 10 all shapes. The file circle end is just under the AA battery diameter
Thank you, i didn’t let the batteries in for long, it must have been the previous owner because i got this at a market very cheap and was trying to restore it
