Pro Boat Blackjack 42 cooling problem
thomasb
Stockholm, Sweden
  1. Crawling
  2. Boating
Hi, I'm trying to figure out why there is no cooling water coming out of the side outlet. It only shoots out of the extra outlet on the rudder. It is possible to blow water through the system. Any theories? Thanks.
Likely something caught in one of the fittings or port on rudder. Try running some single strand wire through. High E string on a guitar should do.
I would blow through it and if you are good there I had an issue with my tunnel blowing hoses off. Super fast boat so hoses would not stay on. Had to order some 7&8 mm steel clamps to put on ALL hose ends. Fixed the problem!
The low E makes for a great hairball gitter-outer in the tub drain. :D
