Ok, it finally got warm enough for me to run my car. I got it tuned fairly well, nice stream of smoke, quick throttle (though it still won't shift). The pull start is no longer THAT easy to pull, which is good. Then I noticed that the radio box was wet, next to the engine.
Turns out, the Locktite worked but not too well. The part of the engine with the stripped screw is pretty secure on there, but there's a microscopic gap only big enough to spray fuel from the mill. It doesn't seem to affect performance too much, or if it does I don't notice.
My question is if I can use Locktite as a sort of "caulk" around where the screw is stripped. It says on the tube that it'll take temps of around 314f degrees. I don't really mind if it doesn't help any performance aspects, I just don't like seeing smoke and fuel spraying out of the engine (who would lol).
Also, as a side note, someone on here mentioned that a two speed tranny should have two screws on it. Mine has two screws right next to each other, the one on the left (looking at it with the front of the car facing away from me) is turnable without much force but the other is stuck pretty tight at the bottom of its hole. Am I supposed to turn both to adjust the tranny? If so, which way for which screw?
