possible broken diff?
devinbrown07
RCTalk Champion
lake odessa
alright, i finally got the truck started, went to take off, only the front wheels will move, the rears are locked up, and they still are, i mean i can't turn them with my hands at all ...then i loosened the skid plate, and i can move them by hand, but it still wont move,
and one more question...whats the easiest way to clean out a flooded engine?
thanks a lot.....you guys are a life saver, i really appreciate it
EDIT:: i will post a vid of it tomorrow, its too late tonight, dont want to upset the neighbors, i already have a loud demo derby car lol
Went i had flooded engine, i take off the glow plug and turn the engine(rotostart or pullstart) for a couple of cranks. then re-put the glowplug and fire it up...:yes:
Any pics or vid of the trucks problem, would help alot
It's possible a rock got into the case. Remove the skid plate and have a look-see through the little peek-a-boo window under the diff.
i did that , and when i turn one wheel, the other wheel doesn't move, so i think something came apart, or broke, to where the 2 sides of the diff arent touching eachother
The old (and I do mean old) savage diff case screws had a tendency to back out, which could cause your issue. Or, your spider gears fried inside the diff.
If you do end up needing a new diff, depending on what's shelled, going on ebay and getting an entire diff case/ring/pinion/bearings is much more cost effective than piecing together the parts at your LHS. You can usually get one for $23-$28 shipped.
could you maybe put a hyperlink to an example of all the parts, cus i have only found the parts seperately...
