- Olympia WA
- Racing
- Scale Builder
- Boating
Post a picture of the hub/nut area bud like thisI don’t know how to get the front Wheele off this micro car does anyone know how? There’s no video on YouTube either. It’s a sc28
Yeah that’s kinda what I thought too. It’s not a actual nut it’s more like a pin. I basically just want to take apart the entire front section. It’s steers In correctly because the Wheele is dirty and needs to be cleanedThese are really hard to make out, they don't appear to have a working bolt. The must attach from the inside somehow.
I found this pic but, I can't make heads or tales from it. The manual on their website doesn't help either.
So is that chrome dot. I'm guessing is the axle? Does it have a pin going threw it? Or does it pull out?. I'm going have to download manual and take a lookYeah that’s kinda what I thought too. It’s not a actual nut it’s more like a pin. I basically just want to take apart the entire front section. It’s steers In correctly because the Wheele is dirty and needs to be cleaned
I want to take this entire section apart
I’m just as confused as you right nowSo is that chrome dot. I'm guessing is the axle? Does it have a pin going threw it? Or does it pull out?. I'm going have to download manual and take a look
Chinesium RCI’m just as confused as you right now
Yikes!!!They are just pressed on. They pull off.
It looks like just roller pins. It looks like it 2wd. So those front pins should pull out or they just don't come off at all.ya, sorry I didn't pay attention, I jumped to the conclusion that the picture Stoner posted was your - it was just sample of what we needed to see. In the picture above showing the inside of the wheel, can you take a more clear picture - that one looks a bit blurry.
No, they come off. I have 3 vehicles like that, different brands, but the chassis all look the same. The wheels just pull off. A bit tight though. Might need a dab of glue putting them back on, but not likely.It looks like just roller pins. It looks like it 2wd. So those front pins should pull out or they just don't come off at all.
Ok so give then a pull as stated above and see what happens. As that's the way I believe they come off as wellYeah that’s kinda what I thought too. It’s not a actual nut it’s more like a pin. I basically just want to take apart the entire front section. It’s steers In correctly because the Wheele is dirty and needs to be cleaned
You just twist and pull. This video:I don’t know how to get the front Wheele off this micro car does anyone know how? There’s no video on YouTube either. It’s a sc28
Oh I'm sure it was bud. So you were able to get the tires off?Alright I will try that
got it! Thanks guys! It was a real pain to get off though.
